ROTS Vader problem
May 8, 2002
79
Anyone els have a problem with your Koto ROTS Vader leaning back too far. The front of the feet on mine are not even touching the base anymore causing him to lean back too much. I tried moving the inner cape to support him, but that has stopped working. Any ideas on how to fix this situation would be appreciated.
Thanks,
Marty
Jul 28, 2006
2,665
Re: Kotobukiya ROTS Vader problem
Mine has the same problem. It's been this way for months. It was getting so bad I had to put some stuff under his base to tilt it forward. It looks awkward, but at least he's not falling back anymore.
May 23, 2005
1,756
The inner cape should come closer to his heels rather than away like a stand - if that fails, try re heating him with a blowdryer and make sure that he is back to his original posture -- then try the cape thing again - close to the heel. Good luck...
Jul 28, 2006
2,665
Thanks for the tip. I'll have to give it a try sometime this week.
Aug 7, 2001
24,677
1,660
Star Destroyer
But why is this happening? Ar the feet holes too large now?
May 23, 2005
1,756
Probably not -- the vinyl is flexible but the pegs are just there to keep him attached to the base - the cape is used to support the extra weight in the rear. Worse comes to worse if the holes are too big, take some pliers or a vice and lightly squuze the feet whilst applying some heat -- or dip in hot water to soften and then use something to squeeze the feet to narrow the holes.
May 8, 2002
79
I had used the inner cape to brace him up for a while, but that no longer works. It is the weight of the main cape that is pulling him back. I have thought about using some sort of epoxy on the front part of his feet to attach him to the base so he won't lean back.
May 4, 2005
6,816
Overland Park, KS
Ghostider, you might want to use something like Goop that is removable if you ever need to separate the statue and the base. Goop tends to be sticky, but can be separated and hand rubbed or peeled off if need be. Epoxy tends to melt plastic together, and I'd hate to hear about Vader's feet getting melt-through issues due to epoxy.
May 23, 2005
1,756
Can you post a photo or 2?
Aug 7, 2001
24,677
1,660
Star Destroyer
The idea is that I don't have that kind of problem with my Vader. That's why I'm curious why sometimes this happens...
Nov 16, 2004
2,626
That is the problem with vinyl and one of the reasons why I stopped collecting Kotos. The kits are amazing but they are definitely weak on their lifespan.
May 23, 2005
1,756
I don't either -- although sometimes if the vinyl is made too thin, it is weaker -- that's why some high end vinyl manufacturers have such high standards in testing the quality of the vinyl...heat makes vinyl prone to melting, so part of the problem could stem from that ... the first vader was a problem because the legs wre hollow when they should have been solid - this the variation in the e.v vader.
Oct 27, 2000
5,202
The first release Vader Koto is much better.
Aug 7, 2001
24,677
1,660
Star Destroyer
Except maybe for his pose - limbo dance Vader...
Feb 10, 2015
8
Bumping this, sorry. I recently pulled this one out from storage and forgot how it sort of leans back even though the feet are planted flat on the base (including the front of the feet). Promo pics make it look like he should be standing up straight though...
