Guide to "futzing" link
Dec 18, 2006
1,508
Guide to \"futzing\" link
I seem to remember a link to how to "futz". Despite owning all the figures, I don't really believe I've futzed one yet (mostly out of fear of damaging it!). Anyone recall this link?
Re: Guide to \"futzing\" link
I had seen the water treatment link tutorial but the link I'm thinking about covered more than that (things like boiling and stuff like that).
Any idea on that?
Might as well ask this here....
Does anyone know how to safely remove the paint from the SS heads?
Okay, if I'm dreaming about this link--let's approach this another way.
Let's CREATE one!!! If you know how to futz (boil, etc.) and have time, how about adding your tutorial here so the rest of us can learn. Akiata gave a GREAT example with his stormtrooper.
I have only seen Dave post 3 tutorials:
1) Jedi Luke water treatment.
2) Anakin robotic arm tuck and general futz.
3) Obi-wan general futz.
Nothing that included the boiling technique (I assume you are referring to popping a head off?)
I'm going to try to find some of those posts. If you have time to help please re-post them here
As for boiling, that was for armor, parts, whatever gets boiled (I'm not 100% sure myself on that!)
Thanks!
As far as "boiling" the stormtrooper armor goes, it's pretty easy:
Boil some water (for the armor plastic, I found it actually had to be boiling to heat it enough to re-shape it, for softer plastic it usually doesn't need to be that hot)
Once the water is boiling, dip the armor into it for about 30 seconds or so. You may want to hold it with some tongs or something like that. Be careful not to get the straps that hold the back to the front in the water as they are much softer plastic.
Take out the armor and rehape it to the desired shape. You could use a naked body as a guide I suppose, but I just kind of eye balled mine.
At this point you can either hold it in place until it cools, or you can expedite the cooling process by holding it in your freezer.
I've used this method with numerous, warped, items. It works great for Hasbro 3 3/4 figures, weapons, ad accessories as well as ship parts (the long, pointy parts on the Naboo fighter and Naboo Queen's starship come to mind). I have also used it to remove 1/6 figure heads and reshape warped items like SS Bespin Luke's blaster. I have never had any mishaps yet.
Note...if you choose to boil water in the microwave, be extremely careful as it can sort of "explode" on you if you aren't careful.
As far as the SS Stormtrooper goes, I have boiled/reshaped the chest armor, secured the front armor to the back using velcro, and touched up the paint on the helmet (painted around the rims of the microphone pieces, touched up the "mouth", and fixed the "asian" eyes. I still need to give his armor a gloss coat, but here he is:
Reposting for Yodacappy:
"DEATH STAR PRISTINE" STORMTROOPER GUIDE
This truely was a very easy custom job, just pretty time consuming.
-Pledge with Future Shine. This is an acrylic based floor wax, that's readily available in US grocery stores. It has the thickness of soapy water, and dries liquid-glass-clear with no tackiness.
-Black Acrylic paint. Acrylic is a water based paint, and easy to work with.
-Liquid Silver Leaf paint. This is easy to find in hobby shops. This stuff comes in silver, bronze, and gold. You could substitute silver acrylic, but it needs to be pretty bright.
-Brushes. Nothing more costly than $3.00- 5.00. This doesn't require fancy brushes at all...just new clean ones (loose bristles in your coat is no fun). The big one in the pic is maybe 3/4", and you can see the others are pretty small.
You need to first start off by washing the armor in soapy water. This will get rid of any mold release film, and allow the future and paint to go on smoother.
To refit the chest armor, I took every thing off the figure except the abdomen armor. I made a hook to hang the armor on so I wouldn't have to drop the glued straps into boiling water. It takes maybe 7 seconds (at rolling boil) to get the plastic soft enough to bend. Using towels I put the chest armor back on, and pressed and held down the sides of the armor to the body. Hold that for about 10-12 seconds, and that's it. It should be perfect that easily. If not, repeat.
The painting I did was primarily to the aerators, the exclusive pistol, and to clean up the black "mouth" and frown. I was considering painting the sides of the boots off white, but decided it was completely unnecessary after looking at film grabs. For the aerators, I thought they kind of looked like silver waffles as is. I painted them completely black, then dry brushed the silver leaf over the tops of the grill and lip. This leaves black in the crevaces, and gives the aerators more depth as well as makes them look smaller.
[[Dry Brushing is when you take paint onto your brush, then wipe and dab the brush on a paper towel until very little to no paint comes off. You then lightly run the tip of your brush onto the contours of the surface you are working on. Go as soft as possible, and don't try to add too much paint in one application. Repeat as much as needed to bring the color more opaque. Dry brushing is how they weather the weapons in this line, and I did it to the exclusive weapon to make it look much better.]] I wouldn't really recommend trying to correct the mouth unless you have a very steady hand and know how to hold a brush.
As I said before, Future has the consistency of soapy water, so brush strokes are not an issue. This is pretty fool proof really. Use the big brush for everything but the gloves. Use the small brush to get the panel on the gloves, and to pull off excessive pooling of the liquid. Apply it in a light that you can see the reflection off of, and do not touch the armor once the liquid is on. I used tin foil crumpled up to hold up pieces of the armor that don't have a flat base. Wait 8 hours after your 1st coat to apply the second coat. You should be able to handle the armor after that in about an hour. 2 coats is the minimum to get the best shine. I see no reason for 3 coats unless you missed some spots, but it couldn't hurt I suppose.
That's pretty much it. It's simple. I've used Future in the past on model aircraft canopies. It makes clear plastic look like glass. It holds up long term, and does no damage to plastic that I have ever heard of. Model makers have used Future for years. Big thanks to Sewbacca for suggesting it for the Stormtrooper and trying it 1st. Excellent idea. Highly recommended.
Could we make this a Custom Help Thread Yoda? Maybe even stick it to the top?
I have some questions about 1/6th True Type and how to make certain parts fit from a buck. Im sure it would be helpful.
Thanks
How much taller is the TT than the short Buck?
Thanks
The TT is the same size as the buck. The PRO is the same size as the small buck.
The longer necks on the Buck figures is what makes them look taller. But the actual bodies (TT vs reg. Buck) are the same size.
Ok so a Jedi Luke on a TT wouldnt look so out of scale?
Basically its gonna be some minor customizing of say hands and head?
Jedi Luke would look like a body builder and he would be too tall. The shoulders on the TT are just too huge for Mark Hamill.
If it were me I would locate a PRO body or a short (non-monkey armed) Buck - like you see on Yavin Luke, Ki Adi Mundi, etc...
On the PRO you just need to buy an HT neck adapter and glue the SS head to it. The PRO would be perfect for Luke. IMO.
Makes sense
Have you seen the Pro Body on Ebay at all?
I haven't. I got mine from a SS Freak who was selling it nude since he put his Indy on a TT body.
What about foot issues on the Pro? Arent the feet and shoe one piece? Would I just pop Lukes feet off the buck and put them on the pro?
Head-TT Neck adaptor glue on SSC head. Short Adaptor?
Hands-Swap out
Feet-?
Thanks
The feet issues becomes more complicated. Without substantial modifications the PRO feet are not compatible with the TT feet. But Luke's boots are made of such a hard plastic anyway I think you could get away with no feet at all.
Im thinking of going with the Pro so my question would be putting lukes feet and boots on the Pro. Im looking at pics and it looks like I could bascially take the feet off the buck and put them on the Pro. Thoughts?
I would need the short TT neck right?
There is an Indy body I saw on ebay right now.
Thanks
Wouldn't hurt my feelings a bit!
You would need the neck that looks like this:
As for the feet, on my PRO I glued the Buck ankle and foot to the bottom of the PRO. Its very Frankenstein, but its going to be covered up anyway. Just make sure that the ankle retains its articualtion.
Sweet.
You just took off the pro feet and ankle at the line near the bottom and glued the buck feet and ankle?
Gonna be looking for Luke soon then the Pro body.
Thank you for your help, Im sure it wont be the last time.
Joda76 said:
Sweet.
Exactly what I did. It doesn't look pretty but it works.
pixletwin said:
Joda76 said:
Sweet.
Like you say though you cant see it and if the articulation is still there so what.
Why do you have to glue the Luke head on the Pro body though? Does it mess articulation up?
You have to glue the Luke head on to the neck adapter because its just a smidge too small for the SS head. The neck still still retain 100% of its articulation.
Gotcha
I wasn't aware anyone was still modding here. I never see Amir or Dave posting here.
Thanks!
If you all don't want to get the armor wet, a hairdryer or heating tool works great too! this is an old skill from vinyl modeling....
What, no mod?! I'm surprised the place hasn't burned down
Amir still has his name tagged down bottom, I noticed.
This is thread derailing, right? We should self-regulate... (why don't you volunteer to mod pixle?)
I have my fill of MODing to last me at least another few decades.
Bump
Can we sticky this Chris?
I have a futzing question:
Is there a safe way to remove the paint off of the SS 1/6th head sculpts?
I think I need to teach myself casting otherwise...
I agree with the sticky request. I'd love to have an easy to access thread on modding and modding questions.
Bump
Can we sticky this ?
Problem solved
Back
