Lately, Shapeways has been getting most of the money that I’ve previously given to Hasbro. I’ve spent a lot of time fooling around with Tinkercad, and it’s a hoot. My first model is the giant mouse droid seen during the Emperor's arrival aboard the DSII.
The tracked giant mouse (rat?) droid only has one point of articulation, the ball-jointed head. The wheeled version has seven, at least by EE exclusive astromech standards – A ball-jointed head and six rolling wheels.
I designed a snap-together two-piece body so that I could screw the neck into place from underneath, but ultimately that wasn’t necessary. The neck has a tight press-fit, but it can still be removed. After seeing the two versions side-by-side, I think I’ll revise the wheeled chassis so that the two versions are the same height.
The GMDs are fairly simple, and completely 3-D printed with the exception of the wheel mounting hardware (#2 screws, washers, and bushings) on the wheeled version, and the #2 screws on the tracked version.
All pieces except the heads are printed with “strong, flexible” plastic. The “polished” plastic option rounded off too much detail, so I used unpolished pieces and block-sanded as necessary. I used Legos as sanding blocks, and went through 150/220/320/400/600/800/1000 grits. The horizontal “lip” at the bottom of the upper shell, the underbody “chassis” piece, and the wheels keep their original unpolished texture --Partially to create an interesting visual contrast, but mainly because it’s hard to block-sand thin areas like the bottom front edge without rounding off what should be sharp edges. The body was painted with Krylon “Matte Black,” and the stripe is Tamiya “Dull Red.” I sprayed the “grille” black, then masked the inner section and sprayed the rim with Rustoleum aluminum. Printing the grille separately made block-sanding easier.
The heads were printed in “frosted extreme detail” plastic, in order to capture the eyes detail. After painting the head, I “painted” the eyes white by letting thinned white Tamiya acrylic ooze into the lens areas. Due to the slick nature of the FED plastic, there’s not much friction between the head and the neck. I tightened up the joint by placing a drop of super glue inside the socket and rotating the head until the glue dried.
On the wheeled version, I used 2mm sections of 1/8” brass tubing as bushings inside the wheels to help them spin smoothly.
Part three coming up.
